RedneckPhysics
- Apr 30, 2015
Hi All,
I recently stumbled upon a fantastic procedure for getting to a great starting point for precise alignment of my Tormach 770. I'm sure many of you have heard of it or tried it... it basically uses a precision level to "map" the torsion that may be present in the base casting about the y-axis for correcting the base stance to be like the factory's 3-point setup when assembling.
From various sources, I've seen that master precision levels work the best (anything that's capable of better than ~0.001" in 12"). I've been able to borrow a low-end Starrett 98 machinist's, and magnify the vial for a little more precision in determining bubble movement. It works, but it's not convenient at all.
In looking at levels that might approach that level of sensitivity, but not break the bank (Here's an example), I've found a few imports on sites such as MSC that could potentially work.
Does anyone have experience with import Inspection Block levels?
This one looks somewhat promising... it's a Japanese import... I might trust it a bit more than Chinese-made instruments, but it's still an unknown.
8 Inch Long, . 5 Graduation Sensitivity 273 - MSC
Or perhaps a French import?: 8 Inch Long, . 5 Graduation Sensitivity 2352763 - MSC
If those can't be trusted as far as you could throw them... what's one worth buying, but under $800 or so?
Mike
Mike
