Greetings,
I'd like to make sure I have not gone crazy - this is really bothering me.
Details are as follows:
Qty. 25
Mat'l - customer supplied MIC 6 - .500 x 40" x 47" (part to finish size as supplied no milling to size required)
6-32 2b tapped thru - 55 holes
10-32 2b tapped thru - 32 holes
Clearance thru c-sink for #10 - 15 holes
Clearance thru c-bore for #10 - 6 holes (c-bores - are on the perimeter and break out the side rectangular)
1/4-28 tapped thru - 15
Clearance thru for #6 - 10 holes
Grand total of 133 holes + 6 c-bores that need to be milled.
I would run this in machining center I can get this in one setup whole part with no farting around chamfer all holes front and back tapping in the machine, form tap etc. etc. quality job Q.C. etc. etc. I figure 2 min per hole as an average - that usually takes care of all the stuff on a drilling job like this and averages out tool changes, move hole-hole, handling (load - spot from back to chamfer backside, flip spot for chamfers and away-we-go finish part). Need to program/ setup etc. which I'm doing for free for the sake of this discussion.
Competition is charging - $100.00 Each
I'm over $200.00 as a rock bottom.
$100 seems insanely cheap
Qty. 25
