Hello,
I'm having a problem with a Sauter turret on an Emco 320 lathe. I saw this machine running with the tool turret working in it's previous home, but it needed to be re-commissioned as it had lost some of it's parameters. I've followed the recommissioning procedure and reloaded the PLC as described by Siemens, but I'm still getting errors:
6025 Tool-turret index failure
6024 Tool turret encoder fault. (this happens as soon as the turret is jogged or moved.
The tool turret is not locking, when I press the rotation button, it just spins without indexing. I believe this is because the parameters in the %TEA1 file are not correct for the machine. In the digital %TEA1 file, it says:
<lines omitted>
N2400 =40403
N2401 =175363
<lines omitted>
But next to this someone has hand written notes that says"NEVER change turret home pos. Jog Diagnosis > NC machine data Axial Data 10/1/09 2400 = 38818 2401 =172730 so, despite it saying "NEVER" change it, someone did in 2009??? (apparently the machine was recommissioned then as well) it's apparent that someone rotated the encoder on the turret as well, as evidenced by the attached picture. I'm not sure why this was necessary. How do I ensure that the values in the parameters match the physical orientation of the encoder?
Took off the cover of the turret, and It's interesting that there is a new witness mark for what appears to be the encoder… someone has had issues before and been in there? I DID see this thing work properly at the seller’s, so I suspect a software problem not a hardware problem.
does anyone have experience with these Sauter Turrets, or know more about the %PLC files and %TEA files that might be able to explain what I should try next? I believe the problem is not a hardware problem, but that I don't have the right parameters in the file and the control isn't able to "talk" to the turret. I do have what I expect are the original parameters in both paper tape format and digital, but I need help from someone who knows more about this than I.
View attachment PCA.txtView attachment PCP2.txtView attachment SPF2.txtView attachment TEA1.txt
<lines omitted>
N2400 =40403
N2401 =175363
<lines omitted>
