fmari --MariTool-
Titanium
- Nov 15, 2005
- Illinois
I showed pics of this a while ago. well here is a short video. The machine is able to detect what position the indexer is in and what location is wanted. It will then select a certain subprogram to index to the desired location. 0, 90, 180, or 270. When it is done indexing if it is not in the right position it will alarm out. No chance of the machine crashing or making holes on the wrong side. Also when it is done indexing 6500 lbs of force is clamping by 28 individual air cylinders that I made on a plate. The entire mechanism is in a oil bath. I machine 6 pieces at a time. From paper to product in about 2 months. I designed and programmed everything. Total parts around $3500.
