implmex
- Jun 23, 2002
- Vancouver BC Canada
Hi All:
What is your preference when you have to make a very accurate 2D feature...say a simple rectangular pocket, but it must be as accurate as you can mill it?
You're only going to do this one feature super accurately and you'll only make one or a very few parts.
My business partner Keith uses a procedure where he will make test cuts to find out how big his cutter is actually cutting, then he edits the cutter size in the CAM program (we are using HSM Works) and then he posts his code and cuts, assuming his part will be on size.
One finish cut, one time and if it's wrong...it's a tosser.
But if it's right, it's only one cut.
I, on the other hand, will program with wear compensation in the control, leaving a couple of thou stock and then increase the comp in two increments, the first to establish how much stock is left, the second to bring the pocket to final size, and if I need truly super accuracy, some spring passes; as many as I need to bring the part to size, gauging as I go with Jo blocks or whatever is appropriate.
One finishing program, run as many times as necessary to sneak up on my dimension and maintain control.
When you have features like this that must be right on the money, do you prefer Keith's way or mine?
Why do you choose the method you prefer?
Cheers
Marcus
www.vancouverwireedm.com
Cheers
Marcus
