Solar71
Titanium
- Mar 24, 2005
- Hermosa Beach California
Hi all...
Im new to CNC machining...
But i was wondering...
Right now at work I...
Get new parts from other manufacturers without blueprints... I then use my Micrometer and caliper and all the other little tools for radii and threads and angle... Then i use Autocad to draw a blueprint for our machinists... with tollerances and everything... Including chomed areas and weldements... Then i take my drawing and cut it up , and export it to mastercam... Then i create the tool paths and all that... Then i generate the program... upload it to the CNC machine, and then edit the program to get it just right for about 15-20 minutes... (my post is not exactly perfect) but no big deal... Then i do all the settup and offsets and everything... Then i run the part too... And double check the first 3 to 5... Ocne that is all done and good, i will pass it to another man at work, and he will run the rest and make sure to adjust for tool wear...
So i can do all the stuff they want...
Remember... this is lathe, i have no clue about mill... But that is what i will learn next...
I was just wondering what someone could expect to make in $ per hour in Southern California for doing this stuff...
PS : where i work is a great place... But sometimes it seems like i never have enough money... and im always living from one paycheck to the next... Is this normal? or should i be making more ?
So what is a fair $$$ per hour figure ???
Also i will be learning CNC milling as well... and once i learn that, how much should i get at that point ?
Thanks again you guys....
