jinx18
- Oct 27, 2014
- Long Island, NY
Hello, I am needing to get a part made on a CNC machine. I am obviously looking to keep costs as low as possible so I am assuming if I can keep the design as simple as possible it will lead to less time on the machine which is less money to make it. Hopefully that assumption is right. Anyway I am totally unfamiliar with CNC Machines so please excuse my ignorance about them. I am wondering how I can keep this part the simplest and cheapest.
I am assuming flat sides are easiest? 90 degree angles? Are curves much more time consuming/costly? Anything I should know specifically?
The part is fairly simple and small.
About 1.5"x1"x1"
Stainless steel. Could be 304, 316 or 303. I am assuming 303 would be my best bet for machineability.
About 1.5"x1"x1"
