Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By thermite
Thread: Quick Change tooling adapter?
    kuraki556 is offline Cast Iron
    Aug 2010
    Midwest, USA
    281
    Default Quick Change tooling adapter?
    We have a large gantry mill, a Quickmill 180, with a nice big heavy right angle head attachment. I would like to utilize the RAH more often than we currently do, and I am looking for some quick change tool holders to do it. The biggest drawback right now, is the RAH has a threaded drawbar for holding tools, and tool changes are a pain. (Threads into retention knobs that have a threaded hole, 50 taper)
    I don't expect to mill with a 6" Quatromill in a quick change tool, but I would like to drill/tap with quick change tools. Does anyone make a drill holder, or tool holding system, that would allow me to install a 50 taper adapter, and then using a ball lock or slider like a tap holder to change out between drills, taps, etc? Rigid enough to use Titex drills? Maybe rigid enough to bore with?
    Thanks.
    Philabuster's Avatar
    Philabuster is offline Stainless
    Jul 2006
    Tempe, AZ
    1,698
    CAT 50 to Capto adapter.
    sfriedberg is offline Stainless
    Oct 2010
    Oregon, USA
    1,692
    There are a bunch of old-school systems, too. Erickson QuickChange, Devlieg Flash Change, SPI quick change in two or three sizes, even Weldon quick change (although that's not as quick). I've got an NMTB 50 to QC 40 adapter that's extremely handy. I use MT drill holders, endmill holders, shellmill holders and MicroBore FC tools in it.
    Mud's Avatar
    Mud
    Mud is offline Diamond
    May 2002
    South Central PA
    9,683
    Quote Originally Posted by sfriedberg View Post
    FWIW, the Weldon system will accept Cat45 tools with a few modifications. That gives you a very broad range of inexpensive tools available used, and it's very sturdy. Requires that you loosen 2 3/8 setscrews to change tools, so it's not the fastest.
    thermite is offline Diamond
    Mid-Atlantic USA, South China
    7,189
    Adding PDQ-Marlin Quick Change to that old-school list...
    Right Angle Heads, Angle heads, quick change tooling, PDQ-Marlin
    Bill
    kuraki556 likes this.
    Greg White is offline Stainless
    Jan 2007
    Pinckney Mi.
    1,929
    quick switch,(spelling) ran a shop full of them,it will do what your asking and more,50 tapers adapters would except up to 1.5 enmil holders,very fast tool change.
    Gw
    Aug 2010
    Midwest, USA
    281
    Thanks a lot guys!
    Aug 2010
    Midwest, USA
    281
    Quote Originally Posted by Philabuster View Post
    Capto would change with a set screw? Similar to Kaiser bore holders/extensions?
