No it has a touch sensor. I do have a master tool with recorded length and can use that to measure the probes length difference with a dial indicator, then do I just record that length in the tool offset length.
I have been scouring all the renishaw documentation but nothing specific about where the results are recorded I'll try editing the tool probe Z off set and give it a shot.
If anyone has written instructions I would love to see it.
Easy to do if you have a tool with a known/calibrated length.
Put your calibrated tool in the spindle, and bring it to your surface you will use for calibration. I usually use the same 2" ring gage I am using for calibrating the X&Y. If your machine Z distance is Z-14.7900", and your tool length is 3.6307", than your surface to gage line value is -18.4207"
Knowing that, you can now run the 9801 cycle. I make a little program like this:
O186 (Z LENGTH CALIBRATION)
(START PROGRAM WITH Z AT HOME POSITION)
(SET G55 Z TO 0.)
G90 G55 X0 Y0 (CENTER OVER AREA TO PROBE)
M59 (PROBE ORIENTATION USE M58 TO CANCEL)
G43H151G0 Z-18.2207 (SET Z APPROX .200 ABOVE KNOWN Z POSITION)
G65P9801T151Z-18.4207 (CALLS CALIBRATION PROGRAM)
(USES Z GAGE LINE VALUE)
M58 (CANCELS PROBE ORIENTATION)
M30
After running this you will see that your tool length offset was properly adjusted.
I didn't include 9810 in the program above because it's just what I use when I am calibrating probes, if you are unfamiliar with the calibration cycles, use single block and/or use 9810 for all movements external to the macro call.
