in pic, you can see the interrupted gap that the semi-finish and finish reamer has to come through
the upper pic represents a cast body
the lower pic represents finished part
here are 2 proposal:
proposal A
1. use drill to drill through the bottom cap
2. use drill to enlarge the entry hole so that the roundness/position of the entry holes will be nice for the next reaming process
3. use semi-finish reamer to go through all features
4. use finish reamer to finish the features
proposal B:
1. use drill to enlarge the entry hole so that the roundness/position of the entry holes will be nice for the next reaming process
2. use a CENTER cutting semi-reamer to go through all features, INCLUDING the bottom cap
3. use finish reamer to finish the freatures
P.S
drill is made by carbide
semi-finish and finish reamer are PCD reamers...
which one will you choose?
does this depends on feature length?
thank you
proposal A
proposal B:
P.S
thank you
