Mud
- May 20, 2002
- South Central PA
I'm repairing a broken 1FT5076 Siemens servo. The mounting end bell was broken, apparently by being hit with a forklift. I disassembled the servo,the rest of the motor seems fine, armature straight, etc, except for the connection junction box and connectors.
I found a donor servo of the same size to rob the end bell and junction box from from. What is required to put it back together properly? It appears the sensor plate in the end needs to be timed to the armature - is it possible to do that without sending it to a service facility with a test bench?
