Richard/SIA
Cast Iron
- May 13, 2007
- No. Nevada
Having gotten very frustrated with trying to keep my 1978 Matsuura MC1000V with Fanuc 3000c control running I am determined to get a newer and smaller/faster machine.
Nothing out there is going to use my old BT-45 tooling so I will need tooling no matter what I buy.
After months of looking at mostly "Ran when parked" machines where the best deals are all on the far side of the country, "As is - where is". I've located a LOCAL Fadal VMC40 M901-4.
It has been extensively refurbished with a new grease pack 10K spindle, rebuilt drive, all three axis ball-screws, thrust bearings and seals, etc.
Under $10K but at the limit of my modest budget once I start buying tooling.
Have been perusing this forum and other venues in an effort to learn more about older Fadals, but it seems seeking info on older machines is like watching sausage making.
So many conflicting opinions and horror stories to balance against "But mine is great!" responses.
I notice the same appears to be true for virtually any "Light" machine.
I also found the back story confirming that HAAS are FADAL clones which explains why they look so similar.
Seller has receipts for far more in parts and labor than the selling price, needs room for a much larger machine.
Pro's I see are U.S. made, that used to be a good thing.
Being local I got to see it run, listen to the spindle, examine the ball-screws and ways.
Seems parts are readily available and not horribly (Cough FANUC cough)expensive.
Only feature I am aware of not having is rigid tap, which I have never had so probably will not miss, but it seems it can be added for under $2K.
This is a box way machine.
Cons, Yah it's old but the ways do look excellent and almost everything else seems to have been rebuilt or replaced by a factory tech.
On-line discussion seems to indicate that the ball-screws are somewhat consumable but not expensive or hard to replace.
Some users complain that the tolerances drift as the machine warms up?
Have seen some discussions of tool changer issues and occasional use of a lubricant to prevent loud changes.
I know Fadal was sort of out of business but are back again.
I'm making mostly small parts in aluminum and 4140 steel, so far I can only dream of having enough work to run this machine hard or more than a couple of days a week.
My Matsuura was usually like swatting flies with a sledgehammer, slowly.
I'm still a bit fuzzy on the CNC 88 control features, -1 and -2, MU = on-screen menu help, etc. but will learn it eventually.
Hints welcome!
Bottom line, I've not found another machine of similar condition within reasonable shipping range at the price.
So seriously, is there something I am missing here and need to know or look out for with a second look?
Is the control actually user friendly or not?
Have to get this right on the first try, no budget for a do-over.
And it looks like I will keep the Matsuura to work on as time permits until I get it running again, since I refuse to pay some one to take it away for what is probably a minor issue.
Hints welcome!
