havocworks
- Nov 26, 2013
- ohio
I have a mighty mv-40 cnc bed will. 54x14 table with box ways. The turcite on one of the table ways pulled out due to a faulty oiler and due to space constraints I can not slide the table off of the saddle without moving the entire machine. I am going to try to remove the saddle and table as a unit, set them on some 6x6 lumber and then separate them on the floor before taking them to have the turcite replaced and scraped in.
I do not have access to a forklift currently but do have a 3 ton capacity hoist. I figure the table and saddle weight aprox 1k-1400lbs as a unit based on browsing ebay for similar sized tables and checking weights. (also was best guess of a relative who is a repair tech at a large manufacturer)
My plan is to run 6x 5/8-11 eye bolts(w/shoulder) in to the t-slot nuts, attach appropriately rated lifting cable or chain, then lift and rotate the entire assembly 90 degrees and lower on to the 6x6's.
Anyone have any advice or suggestions before I attempt this? (other than keep limbs out from under things!)
