My Blaser rep came by and measured the ph and water hardness in some coolant that was sitting unused in a machine for 2 months. He noted that the hardness (or dissolved solids, I think) was a little on the high side. We measured the DI water coming out of my filter system and the hardness was too low to be measured. These measurements were taken with Aquadur 912 01 test strips (http://separations.co.za/fileadmin/...ii. RAPID TESTS/MN_AQUADUR_R__test_strips.pdf).
The problem I was having (low PH and oil coming out of emulsion) was solved by simply adding fresh water/coolant mix. However, the Blaser guy told me that the hardness can be a problem and to remove some of my coolant every year and replace with fresh coolant. I don't like the idea of removing any of my coolant because it is expensive to dispose of (I think I was quoted about $250 for a 55 gallon drum).
So, my question is, is there any way I can remove some of the water hardness from the coolant? Or is diluting the only option? Can I run my coolant through a deionizing filter, or will that potentially cause a problem or be ineffective?
Cheers,
Matt
Cheers,
Matt
