dstryr
- Jan 22, 2010
- Nampa Idaho
Anyone here have it and played with it a bit? Got it working today and messing with it. Cool software. Just eats up a lot of time running, moving, thinking, re run, repeat.
I just looked at the video on their website, looks pretty cool. Our HaasUMC750 came with something like this. It is a sphere mounted on a shaft at 45deg, similar to what is shown in the video, except larger. I have not used it yet, I just watched the setup guys run through it. It runs just like a probe cycle inside the VQC. I think (again I have not done it myself) I record some numbers in the parameters and then run the test cycle and compare them. If they are off by more than whatever the standard deviation is I need to make a correction in the parameters.
Does this software do something similar? I see in the video it outputs information, but how do you fix it if the numbers are very bad? Is it just a checkup tool so you can call a tech and then they come do the work on the machine? Do other machines have a similar offering as Haas, supplying the test sphere and program to do a self diagnosis?
Heidenhain has had this for 6-7 years its called KinematicsOpt.
HEIDENHAIN Places Machine Tool Accuracy On Center Stage at WESTEC
Before that, and still sometimes now, we used a Square block bolted to the table and a special macro for measuring points on the block
So your blends always come out perfect from your cam?
Depends on what the definition of perfect is but pretty close to perfection.
Within a thou would be my goal for positioning and dia perfect if the blends allow it but in tolerance is good enough... And I guess it matters if your starting from a blank or working off of a second operation...fixturing is mostly the limiting factor for me. You can't reinvent the wheel when the setup time says five hours.
couple tenths at most doesn't matter if we start out with a blank or second op we can realign off of planes and cylinders.
It outputs data which allows you to import into a computer and see whats going on with the data points. After you see what is off it is clear what needs to be adjusted. The software will autoadjust but the adjustment isnt always clear and dry. Sometimes its a pivot point adjustment, other times its the center of rotation adjustment. I spent about 4 hours using it on both of my machines yesterday. Going to cut some parts later this week that will show me if I'm any bettter than when I started.
Reason I bought it was because I'm always fighting blends between the bottom of endmills at a0 and the side of ball endmills at say a-45.
The mentioned pivot point and center of rotation adjustment - which Fanuc parameters are updated ?
Sorry machine is Siemens controlThe mentioned pivot point and center of rotation adjustment - which Fanuc parameters are updated ?
Thank you.Par. #19700 through #19705
Notice
