RalphStirling
- Apr 26, 2007
- College Place, WA
My manufacturing lab doesn't have classes every quarter, so
sometimes the CNC lathe and mill will go a while without use.
I discovered today that the 42 gallon sump in the lathe had evaporated
down to about 5 gallons. I sucked it out with a shop vac. My question
is whether it is possible to mix it back up with water and reuse it. It is
Blaser 2000, with about a pint of way lube thrown in. No smell, and about
the same color as the original concentrate.
If it is a bad idea to reuse it in the lathe, I'll just keep it around for
mixing up cold saw and bandsaw coolant.
Clearly I need to come up with a plan for keeping the lathe topped off
during periods of less frequent use.
-- Ralph
-- Ralph
