Old Lathe, your second letter formed my opinion. Being in the firearms business, and theprecision you will need to demand becomes your hurdle in owning or sub contracting the job. I have done a lot of firearms work on machines and in design and programming, but in the end it does not come to the machine as much as it is the quality assurance factor you need.
The cavities of a pistol or rifle body, hole locations, clearances for mating parts. How these are located to each other, the true positions, the form factors. How will you check them as quite a few intricate features demand not only a good machine, but perhaps a CMM, special tooling, things like this if you go into production. The tooling and quality assurance willprobably equal once again and beyond what a machine costs, and the tracking of such will also be a cost - and a liability for the machine company.
This said, if you are looking for a "close to" prototype to work with as a design model, the question is are you going to fire it off in actual use, fit it with other parts, just use it to check form and design then sub contract the actual production. If this is the case, you have a couple of fairly inexpensive options for the "Prototype" aspect. One is something relatively inexpensive like a HAAS toolroom mill where you change the tools by hand. Speed is not as important as the design model. The other option, if all you want is design form and seeing how it comes together is a rapid prototyping machine - unless you are also making barrels (which is a whole seperate ball of worms).
I am in the market for a Rapid prototype machine right now just for this, it will supplement my CNC machines as a design/form proving item. However, the RP machine does not set toolpaths, just the drawing into the plastic or whatever.
If you are thinking production though, you need to look beyond the machine for the QA aspects that are paramount in gun making in volume.
