Rigid Tapping Feeds/Speeds in AL6061
Page 1 of 3 123 LastLast
Results 1 to 20 of 56
    Oct 2016
    77
    6
    Question Rigid Tapping Feeds/Speeds in AL6061
    Hi guys,
    I'm attempting to rigid tap several 6-32 holes in half-inch thk al6061 on my 2005 Fadal VMC 3016. Problem is I have zero idea how to set the speed besides trusting what HSMworks auto-selects for me. Right now I put in HSMworks I'm tapping these holes with a thread-forming operation and it tells me to go at 5000 RPM (feed is not even an option to select). I've been trawling old posts on this forum and that seems a little fast. FSWizard, which I usually trust, tells me to tap at 5000 as well (well, 4985).
    How would I calculate or confirm that this is about right - or wrong?
    Jul 2012
    Washington
    2,004
    723
    785
    Tapping speed for a 6-32 form tap in aluminum is all about how fast you can go with your machine. With a Fadal I would start around 1000 rpm and go from there depending on how it sounded/worked. What is the max tapping rpm for your machine? Depending on your spindle inverter I may cut that speed in half as a general rule of thumb.
    Sep 2015
    Ohio
    688
    389
    700
    As long as the feed is calculated correctly to the programmed RPM you should be ok.
    Your machine is not going to reach 5000 RPM in 1/2 inch.
    Jun 2012
    Michigan
    3,629
    3061
    2092
    As said above, you can go as fast as your machine will allow.
    #6-32 tap at 5k is only 156.25 IPM feedrate. But the sync is the key here. Pay attention to the spindle reverse and how it acts.
    Aug 2017
    Minnesota
    33
    5
    13
    A form tap in 6061 Aluminum should be at around 180-250 SFM so the 5,000 RPM recommended is right on and is a great starting point.
    Oct 2016
    77
    6
    Quote Originally Posted by ToolHIT View Post
    Great, thanks everyone. So just so I understand, these formulas for calculating feed and rpm hold true for taps as well. For all CNC tooling?
    SFM = RPM X .262 X Tool Diameter
    RPM = SFM X 3.82 ÷ Tool Diameter
    IPM = RPM X IPT (CLPT) X Number of Flutes
    IPT = IPM ÷ (RPM X Number of Flutes)
  7. Likes ToolHIT liked this post
    Jan 2017
    Oregon
    933
    173
    662
    Quote Originally Posted by ProjectZero View Post
    Calculating speed is the same for anything- SFM/dia*.26=RPM
    Feedrate for taps is simply RPM*pitch. A 1/4-20 has 20TPI. 1/20=.05" pitch. So a 1/4-20 tap at 1000 RPM would feed at 50 IPM. (1000*.05)
  9. #8
    Jan 2014
    Washington
    2,872
    561
    1429
    I program all small threads at 6k for aluminum. Since small threads are never very deep, the spindle never gets there, but it is tapping as fast as it can. So far so good....
  10. #9
    Jan 2017
    Oregon
    933
    173
    662
    Setting the R plane a little farther above Z zero can help get the RPM's up before the tap starts cutting. I usually put the R at Z.5 on small taps.
  11. #10
    Feb 2013
    Northern Mn
    384
    81
    408
    You guys are crazy I have spent more time and grief in my life picking broken taps out of expensive parts than I ever spent on tap cycle time. This would be different if I had thousands of holes to tap, but generally, I have a couple of tapped holes in each part. I run my cut taps at 500 and my roll taps at 750... and I still pucker up on each tapped hole. I have all of the numbers memorized for these RPMs and just before that evil little tap starts his first hole, I push pause, I look at the code and look for a G84, and check my feed rate and rpms... then I close my eyes, and hit the green button. While it is tapping that first hole in an expensive complicated part, I stomp my right foot repeatedly so I can neither hear, nor see that little MOFO break off in the hole.
    Did I mention that I hate taps They are just waiting for an opportunity to ruin your day.
    6-32 Cut Tap 500 RPM/ 15.625 IPM
    [On fast and tight machines and any sort of volume I will bump up to 1000 RPM/ 31.25 IPM]
  12. Likes EnderDRM liked this post
  13. #11
    Jan 2007
    Norfolk, UK
    16,900
    12542
    12028
    How can it? cutting speed and feed are 2 different parameters.
    Speed is based on material being machined and cutter material, with workpiece and cutter rigidity having considerable effects.
    When milling or drilling, feed boils down to so much per tooth per revolution.
    When tapping or threading, feed HAS to be in the Z axis and can ONLY be the pitch of the thread per revolution, .or you will NOT get a thread.
  14. Likes Illinoyance liked this post
  15. #12
    Jan 2014
    Washington
    2,872
    561
    1429
    Quote Originally Posted by G00 Proto View Post
    You guys are crazy .....
    Maybe sometimes . I rarely work on really expensive pieces so that helps the pucker factor. I almost always drill or interpolate the hole near the max minor diameter. On some of my parts that have a fair amount of surfacing, I'll get the drilling and tapping done as early as practical then do the time consuming surfacing. That way if I do break a tap, then it's no where near as big a loss.
  16. Likes Hazzert liked this post
  17. #13
    Oct 2016
    77
    6
    Damn. I just broke my tap.
    First my mill was throwing an error "Thread Lead Not Specified". I go into my fadal user manual and look up the line is question. Sure enough I find G84, and it turns out the "Q" is missing. I trusted you, Fusion 360 CAM module! So first I manually add in Q.03125. Now my line of CAM looks like this:
    N815 G98 G84.1 X2.125 Y1.5625 Z-0.535 R0+0.15 S5000.2 F156.25 Q.03125
    But my tool still broke! It seemed go down fine, then to break upon reverse. What did I do wrong? I pre-drilled using a brand new .1065 drill bit. I can try G00 Proto's advice and knock the RPM down to 500 (from 5000!). Thoughts?
  18. #14
    Jun 2012
    Michigan
    3,629
    3061
    2092
    Thoughts?
    Always start out slow, and run it without a part in the vise (or tool offset way above part)to see if it's running correctly.
    Your Fadal might not be able to tap at high speeds.
  19. #15
    Oct 2016
    77
    6
    Quote Originally Posted by Mtndew View Post
    I'll knock it down and try again. I'm not in any rush.
    About eight months ago - the first and only other time I tried rigid tapping on this machine - I successfully tapped about 100 1/4-20 holes. I checked the operation and my feed was at 500! Granted it took hours to do that, but that's unimportant right now.
  20. #16
    Jun 2012
    Michigan
    3,629
    3061
    2092
    500 doesn't seem right for 1/4-20. Does it use decimals? Can you post that line of code?
    Granted I don't know Fadal language, but 20 tpi is .05 per rev, and without decimals it would be shown as 500
  21. #17
    Oct 2016
    77
    6
    The code I'm about to try right now, with my 6-32 machine tap, is this:
    N815 G98 G84.1 X2.125 Y1.5625 Z-0.535 R0+0.15 S500 F15.63 Q.03125
    I don't have the original code I ran to make my fixture plate but I regenerated it and the code I got was:
    N85 G98 G84.1 X1. Y0.5 Z-1.2756 R0-0.3 S500 F25.
    Again - Fusion 360's fadal postprocessor seems to be broken and it is not including the Q (screw lead/pitch) code.
  22. #18
    Nov 2013
    Utah
    2,328
    637
    1223
    10,000 RPM is right at F500.
  23. #19
    Feb 2012
    CANADA
    Ontario
    1,097
    83
    410
    I think it would have problems rigid tapping such small hole at high RPM
    Most of the machines I worked on did OK up to 2000 RPM.
    If you had a compensation holder, you could tap no problem.
  24. #20
    Jun 2006
    Thunder Bay Canada
    1,731
    478
    265
    I used to hide behind the control until the first hole was successfully tapped. Still get stressed when I hit the start button when tapping.
    (And I only use floating holders)
