DeadNutsDan
- Jul 13, 2016
Ok so I recently purchased a robodrill t10, I just got my 1st program on the machine. A simple slot. The feed rate I'm using in the video for the ramping circular interpolation into the material is 60ipm then when it reaches the floor it is supposed to speed up to 100ipm. Instead however it slows down its speeds rapidly as if it cannot process the lines fast enough and then gets jerky and pauses. Would this likely be a parameter that has been changed? Or is this as fast as these old girls can process code? Any and all advice helps. Thanks the link to the video is below
YouTube
Dan
YouTube
Dan
