ROHS Standard
Results 1 to 11 of 11
Thread: ROHS Standard
    Aug 2011
    Detroit, MI
    49
    Default ROHS Standard
    I just got an order with an ROHS standard requirment. Is anyone familiar with this?
    May 2006
    kent ohio
    599
    99
    37
    I had to show on one job that I was ROHS compliant. I believe Europe started this.The material I was using was 360 brass and if I remember correctly it had to deal with mercury in the materials used.
    Aug 2002
    West Unity, Ohio
    22,870
    3248
    6267
    Yeah - I'm not sure that 360 brass will pass ROHS.
    12L14 does sqeek past.
    Think Snow Eh!
    Ox
    Apr 2010
    IN, USA
    547
    9
    172
    I've just seen rohs in relation to electronics. I thought it was more to do with lead as I've seen stated. Perhaps to eliminate all metals they consider harmful.
    What's that on, medical stuff?
    Jan 2006
    Connecticut
    1,441
    514
    636
    Restriction
    Of
    Hazardous
    Substances
    Pick your poison
    Aug 2011
    Detroit, MI
    49
    The part is used in an electrical capacity. The standard has to do with Lead, Cadmium ect in the finished product, but does that mean it effects what cutting fluids you can use in the process of making the part?
    Aug 2011
    Northern Germany
    1,448
    744
    788
    No, the product has to contain less than a given percentage of certain poisonus substances. The aim is to lessen impact of improper recycling, like those poor fellas burning up E-waste in Africa.
    Certain things are exempt. Mil-spec for one.
    Safety relevant stuff like medical and aircraft electronics too.
    Jan 2006
    Connecticut
    1,441
    514
    636
    I've had to make some parts that were RoHS compliant. Here's a list of stuff on the cert I had to fill out. I cut and pasted this from the paperwork that I received from my customer:
    This document certifies that the XYZ Co. Part Number(s) listed in this document and supplied by:
    XYZ Machine co.
    do not contain the substances listed in the table below in concentrations exceeding the Maximum Control Value (MCV), and will be compliant as of the date shown by signature.
    Substance Maximum Control Value
    Lead 0.1% by weight (1000 ppm)
    Mercury 0.1% by weight (1000 ppm)
    Cadmium 0.01% by weight (100 ppm)
    Hexavalent Chromium 0.1% by weight (1000 ppm)
    Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm)
    Polybrominated Diphenyl Ethers (PBDE) 0.1% by weight (1000 ppm)
    Products containing the substances listed in the table above, in concentrations below the MCV, are understood to be in compliance with Directive 2002/95/EC of the European Parliament and of the Council of 27 January 2003 on the restriction of the use of certain hazardous substances in electrical and electronics equipment (RoHS Directive) in accordance with the definitions set forth in the directives.
    Hope this helps.
    Aug 2011
    Northern Germany
    1,448
    744
    788
    Well I figure the metals are kinda obvious.
    These Brominated things are Flame retardants IRC. Again, an electronics only issue...
    May 2006
    kent ohio
    599
    99
    37
    Quote Originally Posted by troyscrew View Post
    Lead!
    See I knew it was one of those carcinogens. Looking back c3600 half hard brass is rohs exempt. How can that be?
  11. #11
    Aug 2002
    West Unity, Ohio
    22,870
    3248
    6267
    Quote Originally Posted by masome View Post
    Lead!
    Apparently someone has become intimately informed of how expensive the alternative is. ???
    Not neccessarily the cost of the material, but the cost to machine it.
    https://www.chasebrass.com/productline/index_greendot.jsp
    Think Snow Eh!
    Ox
