Wsurfer
Cast Iron
- Apr 1, 2013
- Austin Texas
Hi All,
I recently took a job in the semiconductor industry as a design engineer. I've been machining my own designs for a few years on the puny machine in my garage. When they found out I could do CNC, my machine has been running a lot for smaller parts. We use a lot of in house fixtures for our process that are large (to me, too big for my machine). The parts are ~ 22" diameter 3"-4" thick made from 6061-T6. The parts are nothing complicated. Imagine a large Pie plate with pockets/tapped holes with a minimum wall thickness ~.25". They want me to bring the machining process in house due to our need for very fast turn around. Looks like my budget would be around $40K for.. I'm thinking of a used HAAS. These parts do not require any tolerances better than ~.008". From what I've seen these parts exceed the Y travel for machines in this price range. I've made large parts (plastic)similar on my mill by machining half/rotating 180 degrees,indicate, and finish the opposing half. Would it be possible to use a rotary table laid flat to simplify the machining of a part this large ?. would a Rotary table be rigid enough for aluminum used in this configuration ?.
Thanks in advance,
Matt
Thanks in advance,
Matt
