4) A tech rep at Royal tells me that I should see 3/16 throw at the closing sleeve.
Should and reality is a different story with the Royal.
I have one and I hate the miserable thing with a passion!!!
I've said this almost 2 years ago that I'll be buying a Microcentric flex setup and give away the Royal ....
Well, it hasn't happen yet. But it will.
Nonetheless, mine was cleaned last weekend ( monthly occurance nowadays if I'm milling on the lathe , small chips )
Just verified it, it moves no more than .110, and that is ALL IT CAN POSSIBLY MOVE!!!.
If you take yours apart, you'll see that the standoffs of the sleeve is only .125 longer than the center block.
That length difference is what defines it's full travel range.
I still don't see however why you have a difference in throw depending on how much you screw the chuck body onto the drawtube?
Just so we're all on the same page, this is how you mount the chuck:
1: You extend the drawtube
2: You screw on the chuck as far as the threads let it
3: You back off just until the boltholes line up for the first time.
4: You retract the drawtube, which in turn pulls the closer body onto the taper
5: You tighten the bolts
