Slapstick
Cast Iron
- Nov 4, 2004
- Ontario Canada
In our shop we mainly are not doing production work, and really only use our controllers for height offsets and zero pickups, any other changes we do in cad/cam.
My question is with wear offsets, i've seen them on controllers and want to know how they work.
Couple of questions.
Say i am using a .625 cutter, with it being on size, i leave the wear offset to zero. Say i want it to cut a 2d profile .010 oversize. Would i enter +.010 in the wear offset? or +.005? (do you enter the full amount or half?).
OR, what if you are using an undersize resharpened cutter and want it to still cut on size. Say the program is programmed with a .625 cutter, but the cutter is .615 (.010 undersize). Would i put a - or + wear tolerance of .010? The cutter is already a -.010, so i'm assuming i would enter a +.010 to 'fake' a .625 cutter?
I'm sure it's simple when practiced, but i've never used this featuer.
