Results 1 to 3 of 3
    barbter is offline Stainless
    Oct 2007
    UK
    1,247
    Default Running Centre~Tailstock Pressure
    Hi All,
    Our CNC Lathe tailstock pressure is too high for small shaft work. Even with the pressure wound down.
    So, are there any running centre's on the market where you can manually adjust (light spring pressure and then lock up???) for fiddly work?
    Cheers,
    Terry
    WILLEO6709's Avatar
    WILLEO6709 is online now Diamond
    Nov 2001
    WAPELLO, IA USA
    4,105
    depends on how fussy is fussy. I commonly do work in the 3/4 inch x 12 inch range in 4140 prehard out of the headstock on a center.... my Cincinnati 12U x 60 tailstock psi is about 80 I think...chatter gets insane trying to go a full 24 inches.
    SwissPro's Avatar
    SwissPro is offline Hot Rolled
    May 2006
    Illinois
    951
    Use a "linear compensating center" which is a fancy way of saying spring loaded center.
    http://www.riten.com/products/live_c..._live_centers/
