Santa Just dropped this off in my garage - new Hurco VM10
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    Dec 2017
    New Jersey
    19
    9
    Default Santa Just dropped this off in my garage - new Hurco VM10
    A few months ago I decided to bite the bullet and put a more serious VMC in my garage. I had an older Prolight 2000 that I completely rebuilt with Mach4 and some nice Teknic servos, but it just wan't cutting it any more. I had also been using a Haas VF2 SS at a local maker space for awhile so I got to know my way around a "real" machine with a Cat40 ATC, probe, etc.
    After lurking around on this forum and doing alot of research, I decided to go with a Hurco VM10i Plus. The Plus isn't even on Hurco's website - but its a VM10 that includes alot of options as standard (chip auger, dual screen, spindle chiller, etc plus a 12k Big+ spindle from their VMX machines and some upgraded ballscrews.
    The other machines I looked at were Haas Mini Mill and Brother X700, and even a DMG Mori 700 MillTap. I know my way around the Haas control (although I can't say I like it) but the SMini has a much smaller bed in the same footprint machine (20x12 vs Hurco 26x16). The Hurco is really very compact for its travel sizes - Only 6' x 5' and 80ish inches tall. It was an easy fit under my garage door. The riggers drove it right in (hopefully before any of my nosy neighbors could see!) With the holiday it will be another week or so before I can get it powered up and have my dealer back out to finish setting it up, so its going to painful, but at least its in the door!
    Thanks to all the other machinist that have posted threads about machines in their garages - helpful to know that I wasn't (completely) crazy to try and do this..
    Feb 2013
    Northern Mn
    355
    77
    386
    Congratulations, that is a cute little son of a gun. How about a few specs on the new machine... rpms, feed rates, rapid rates, tool change, cost...
    PS I don't think that little 120 volt outlet behind the machine in picture 3 is going to run that machine
  3. Likes Bluejeep, Greg White liked this post
    Dec 2004
    uk
    11,998
    3243
    5261
    Sure sits nicely in that little alcove like bit with the window!
    Sep 2013
    Oregon
    606
    395
    201
    Nice does it have a jog pendant as well or is just the buttons?
    Sep 2017
    Wisconsin
    41
    16
    Congratulations! I wanted a VM-10, but was told by Hurco (and a local dealer who had one on the floor) that there was no way I could get it under my 80" garage door without significant disassembly. Are you sure you don't have a standard 7' door?
    That thing looks great - now I will forever wonder if I could've fit a Hurco when I look at my Sharp.
    Nov 2002
    2,985
    1234
    628
    Congratulations! I own a VMX, and have not regretted the decision.
    Hurco makes really good machines, for what I do. This machine handles typical stuff, but also a lot of aluminum molds.
    Doug.
    Jul 2012
    Washington
    1,878
    651
    714
    Congratulations on the new machine! What is the upgraded ball screws? If that mill is as low as it looks, like my little Kitamura, you may want to have some steel plate feet flame cut. I had some cut from 3" plate and it really helped put the mill at a better height for me, just make sure it doesn't cause problems for the auger and coolant tank.
    And damn nice garage!
  9. #8
    Jun 2012
    Michigan
    3,495
    2862
    2027
    Awesome!
    Congrats! Post a video of chips flying as soon as you can!
  10. #9
    Jul 2012
    Washington
    1,878
    651
    714
    I was just looking through your photos again, that looks like a nice little mill, and noticed in photo 3 that it looks like there is some thick flooring the mill will be sitting on. If this is true then you should remove the sections under the feet so they are setting on bare concrete.
  11. #10
    Nov 2007
    marysville ohio
    8,444
    2385
    5303
    Quote Originally Posted by TonyStark View Post
    Are you going to put Mach4 on the Hurco?
  12. Likes digger doug, adama liked this post
  13. #11
    Jan 2009
    Ohio
    739
    166
    314
    What is the garage door height? Std 7'?
  14. #12
    Dec 2017
    New Jersey
    19
    9
    Quote Originally Posted by G00 Proto View Post
    Sure thing! - here are some specs:
    26"x16"x20" XYZ
    12k Cat40 Big Plus Spindle, 15hp, 20 ATC, Rigid Tapping
    945ipm feed / rapids, 2.5sec tool to tool
    The "Plus" version includes the spindle chiller, chip auger, and some software stuff as standard that I would have gotten anyway
    Other options I got were - dual 19" touchscreen, Renishaw Probe
    The VM10i lists for $59k, I paid a bit more than that with all of the options / plus model.
    Also, the footprint is around 6' x 5' so nice and compact overall.
    As far as the outlet - it is a 20Amp - will that work? Actually my electrician just ran a 100amp subpanel - probably overkill but will give some extra room for other toys. I have a American Rotary phase converter that needs to get hooked up still.
    Quote Originally Posted by DavidScott View Post
    Quote Originally Posted by adama View Post
    That little alcove has a flat floor - so its just raised from the garage that pitches towards the garage doors. Thicker concrete as a bonus. The "thick flooring" is just a 3" step - its all coated with epoxy finish so it almost looks like vinyl flooring.
    Quote Originally Posted by countryboy1966 View Post
    Quote Originally Posted by Rick Finsta View Post
    My door is 7-10" clear opening, its an 8' door. The machine is around 85" without the feet, and you can get that down about another 6" (I think) if you remove the motors for the toolchanger and maybe the Z - which really wouldn't be that hard. I found a video on youtube from Hurco UK that mentions you can get it in a 2 meter (79") door so it can be done.
    Quote Originally Posted by moonlight machine View Post
    Not sure if that is a joke?
    Quote Originally Posted by B-Mathews View Post
    Its got a jog pendant - it magnetically attaches to that cutout in the control so you can use it from console as well.
  15. #13
    Sep 2010
    Vancouver Canada
    633
    406
    197
    What are you doing for three phase power? Nice setup at any rate.
  16. #14
    Jul 2012
    Washington
    1,878
    651
    714
    Quote Originally Posted by rcoope View Post
    "I have a American Rotary phase converter that needs to get hooked up still." From post #12.
  17. Likes rcoope liked this post
  18. #15
    Aug 2002
    West Unity, Ohio
    22,707
    3163
    6158
    Current artical in CTE has users praising the Hurco controls.
    Poll offers snapshot of what matters to CNC users | Cutting Tool Engineering
    Think Snow Eh!
    Ox
  19. #16
    Dec 2017
    New Jersey
    19
    9
    Thanks for the link, it makes me feel better about my purchase!
    I come from a design / engineering background - and while I have no problem picking up a new UI, most of the ones out there just seem backwards. The big guys like Mazak and DMG seem to be on the right track. Haas and Fanuc just seem archaic. The "little" guys like Tormach and Mach 3 /4 have controls that are easier to pick up than most.
    One thing that drew me to the control of the Hurco was the conversational. While I won't use it a whole lot as I can do most tasks quicker with CAD/CAM packages, little thing like facing, boring etc are nice to have in the control. Also, when I expand out of my garage and start hiring, alot of my hires will be people with design and engineering backgrounds - I want them to be able to prototype and build their ideas on their own - and this is a great machine for that.
  20. #17
    Sep 2017
    Wisconsin
    41
    16
    Well now I'm having a bit of buyer's remorse! Congrats on your new machine, keep us updated when you're making chips.
  21. #18
    Dec 2017
    New Jersey
    19
    9
    Those Sharp's are nice machines as well - I forgot to mention that when I listed the other options I looked at. The rapids on those machines are double what the Hurco is. The enclosure is nice as well that it doesn't feel like you are working in a cave.
  22. #19
    Nov 2007
    marysville ohio
    8,444
    2385
    5303
    26"x16"x20" XYZ
    The only reason I ask is all you Mach guys think it is the greatest, yep Mach and steppers, now that's the shit man!
  23. #20
    Nov 2010
    Tustin, CA
    204
    92
    38
    Nice machine. Hurco has been on my radar for one of these days when the time comes for a new machine. Limited choices on machines that fit through a standard door.
