Jrill
- Feb 11, 2013
- Northeast USA
So I've never used a saw without a keyway before. It's a robbjack 3" diameter 0.125" thick 30 tooth saw for nonferrous, 1" arbor hole.
How tight should I make the screw holding the saw? Usually with keyed HSS saws I have done about 45ft/lbs, is that sufficient?
Also, can I use pretty much any old arbor? The one I have uses a 1/2-20 screw with a head that is 1.187 diameter. Is it fine or normal to secure a keyless carbide saw by basically only a 0.09-wide rim around the edge? I would love to use one of Robbjack's arbors but I need to be able to reach down a little over 2.5".
