knull
- Dec 14, 2014
- Birmingham
Hello everyone,
First time posting, so thank you for taking the time to read and respond.
I'm torn on what to do, My company purchased a couple of CNC Mills(haas) to do our production parts, originally the plan was to prototype and then do production but as the company has grown it has become tough to get the prototyping in the mix. A lot of our prototyping can be computer simulated but the final product must be produced to get the actual real world results and bugs worked out.
Anyway I'm seriously considering purchasing a smaller CNC just to house in the engineering office, we have a 3D printer but it is only good for small parts and can only go for fit and feel and not actually be used as a prototype. We really don't have the room for a larger machine but I would like to be able to run a part that is 30" X axis, 15" Y axis and 10" Z height. They are not firm but looking at future parts. The size average part height currently not including fixtures is about 2.5"
I currently use Autocad and Autodesk inventor for part design and assembly. I'm currently intrigued by Autodesk Inventor HSM add-on since it is a CAM program that should be easy for me to transition to because of my inventor environment background. Normally I pass the files and drawing on to the machinist and they produce the G-code etc. this machine I will be doing it all.
Once again it is a prototype machine so not wanting to run production on it but would like something easy to operate to a point.
So here is my question what direction should I be looking in? and has anyone else been in my shoes and found something that worked out that is some what cost effective?
Are the Knee Mill CNC really worth it? Can they do what I want and work with my Software?
The tormach PCNC looks as if the X will not have enough travel. Is there a machine that is in between this CNC and a Larger one such as a haas VF4ss, that can do the travel needed?
Ok I hope I explained myself enough and hopefully I'm not the first person to have been in this situation, and some one has a good solution to offer in the direction to go.
Thank you again,
Kyle
Thank you again,
Kyle
