PriddyShiddy
Cast Iron
- Mar 1, 2011
- anaheim, ca
My new to me Hardinge ST220 is so close to not being a paperweight I can almost hear the parts hitting the basket.
Got batteries changed and getting the 300 alarms. Tons of sources quote the exact same procedure. No problem. Did it on the X and worked... sort of. For the reset to 'work' it seems it needs to BE in the exact 'home' position. How on earth do you do this on a swiss type machine???
On a mill, no big deal for the Z just use blocks off the table. Without turning a center in the collet (which I can't get the machine to move to do) how do I set the x 2.74" from centerline or the Z 9.646" from face of spindle??? Those are the ONLY references I can find in the manual. It shows errors on main and Sub... how do I set the sub? If I jog the Sub Z it over travels. Same on Y, and main X and Z and shows errors for all except X which I just eyeballed.
Lost here and hoping someone can help me make sense. How do I get to the magical position without absolute position or any known position to measure off of?
