Set Up Sheet - Can you share one?
Results 1 to 13 of 13
    Nov 2006
    Montco, PA
    511
    41
    46
    Default Set Up Sheet - Can you share one?
    I'm looking to make a set up sheet for our VMC. Something that goes with each job. It would specify the tools used, tool numbers in the machine, modifications to offsets, notes etc.
    Before I start going at it in excel I was wondering if someone has a good one they could share with me that I could use as a template.
    TIA
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Quote Originally Posted by G-Auto View Post
    TIA
    It's really easy to do it yourself....
    I used one to just make it for EVERY JOB I BID...
    each operation was a line item...
    sorta like this....
    OPERATION........................Set Up.........RUN.........Subcontract Cost
    5 Cut off Bar 4
    10 Mill ,Drill, Tap, Debur..........30 ...........16
    15 Anodize........................................... .................. 4.50
    20 Paint............................................. .....................3.40
    25 Package/Ship.............................................. .........5.00
    You get the idea... and then IF you win the job you make the cnc programs and be sure to note them on the sheet in case of a repeat..Oh I also kept it all in a folder with a 5 1/4 inch floppy with all the stuff on it....Shop Traveler, SetUp sheets for each cnc mahine... today I guess just a bigger hard drive would do.
    Put fixture costs, any special tooling etc in there and use the math available in the SS to figger dif quantity costs and rerun costs etc...
    Put it all in a JOB FOLDER and heep track of it by customer name and part number..
    I could go to the little XT pc that did this with either the part number ( only part of a number was really required ) or the National Stock Number that the govment called it and find everything I needed to know about it...
    It's eazy.. you get to include everything YOU WANT
    Aug 2007
    Edmonton,Alberta,Canada
    384
    77
    Excel is a good format to work with. We wrote a utility that projects a Mastercam toollist right into the appropriate cells of the template and it's easy to grab pictures and paste them on the pages too.
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Quote Originally Posted by Curt B View Post
    WOW... imagine that... what will they think of next
    I thought about using a Poloroid...
    Apr 2006
    Westside of America.
    3,288
    665
    875
    Quote Originally Posted by Gary E View Post
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Quote Originally Posted by Joe788 View Post
    Whutz your problem... it was the mid 80's
    Did you have a digital camera then ?...
    Dec 2008
    sc usa
    158
    25
    Default See Attached
    This is the one that I made up a few years ago. I made it in Open Office. I think that I can save it in other formats. Let me know.
    Hope this helps
    Attached Files Attached Files
    May 2006
    northwest ARK
    2,927
    4172
    395
    Thanks Machfab,
    I've been working on one & adding things as I thought of them. Yours fit the bill perfectly.
    JAckal
    Dec 2008
    sc usa
    158
    25
    Thumbs up
    Glad to help. If you look in the upper right hand corner of the sheet, that is my machine listing. I just circle the machine that the setup is for.
    Jan 2007
    Ontario, Canada
    478
    192
    438
    Here's what I use. 3rd revision so far. The big blank area is for a screen dump from CAM, the rest should be self explanatory. I keep it open on my desktop, and fill it in as I program.
  11. #11
    Feb 2007
    Joplin, MO
    351
    82
    16
    Here is one we developed at a shop I worked at 15 yrs ago and I have tweeked for my shop now.
  12. #12
    Feb 2007
    Joplin, MO
    351
    82
    16
    Finally got it to attach.
    Michael
  13. #13
    Nov 2006
    Montco, PA
    511
    41
    46
    Thanks for all the help guys...................
