need to DNC from Edgecam communications to takisawa(1988) fanuc OT control.
can anybody tell me how?settings,parameters,handshake,etc? lathe is rs232 connected.
not familiar with this setup.
thanks
[FONT=Arial, sans-serif]The crystal controlled clock oscillator (XO) is a device that achieves its temperature stability from the quartz crystal's inherent temperature stability (see also crystal oscillator). This characteristic is typically specified in tens of parts per million (ppm). The initial accuracy at room temperature (+25 °C) is dictated by the calibration of the crystal for the most part. A typical calibration tolerance for an AT crystal would be ±10 ppm.[/FONT]
[FONT=Arial, sans-serif]A frequency adjustment circuit could be incorporated so that the nominal frequency at room temperature could be adjusted for aging. This frequency adjustment would be achieved by use of a trimmer capacitor and the typical adjustment range would be ±10 ppm to ±20 ppm. With this type of adjustment the frequency at +25 °C could be set to ±1 ppm typically.[/FONT]
Notice
