SFM Formula?
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: SFM Formula?
    Feb 2010
    Buffalo'ish
    9
    Default SFM Formula?
    When I first went to a local trade school, and we were figuring SFM for drilling, we were taught the formula sfm=4xcutting speed dividedby tool dia.. I've been doing cnc milling for now 10 yrs. and always had a programmer with the exception of one shop. today, my programmer gave me a different formula thats sfm x 2.82 (ithink) x tool dia. which one is right. i found that if i tried to figure 100sfm in cast iron using a .120 (#31)twist dr. @.0025ipr i get a different result using each. and then me and said programmer got into a little tift about his speed and feed of the .120 drill. he had prog. for 325rpm @ 1ipm. seemed way tooooooooooooooooooooooooo slooooooooowww to me, so i gave his little formula a try and came up with about 3200rpm @ 8ipm. the said i was crazy. i tried it any way, and whuddya know, 4 hole, .3 dp @ about 1 min as opposed to his way @ about 4mins. i figured his sfm to be about 12. again, which one is right?
    jts
    Nov 2008
    Chicago, IL
    1,550
    74
    140
    SFM does not equal RPM.
    The Revolutions Per Minute formula is correct, but not for Surface Feet per Minute as you say:
    4 x Cutting Speed / work diameter = RPM. (IIRC, 4 is just an approximation used for Pi)
    SFM is close to the formula your programmer gives, but is actually:
    diameter x .2618 x RPM = SFM
    Jun 2006
    Thunder Bay Canada
    1,731
    478
    265
    RPM = sfmX 4/diameter of cutter
    The actual value for the constant 4 is 12/ Pi or 3.8197.
    The other formula is pretty close and easier to use.
    Feb 2007
    midcoast U.S.A.
    930
    10
    62
    Quote Originally Posted by Arthur.Marks View Post
    Actually, there is ONE case where SFM=RPM. When the diameter (of part or tool) is 3.82".
    Dec 2007
    Monmouth, OR
    368
    32
    27
    I have heard of both but I personally use 3.82 x SFM / D
    Aug 2002
    West Unity, Ohio
    23,122
    3433
    6408
    The formula in the Titex book (I think that's where I got it?) uses 3.8
    Think Snow Eh!
    Ox
    Nov 2008
    Chicago, IL
    1,550
    74
    140
    Quote Originally Posted by metaltech View Post
    Learn something new everyday! haha
    Mar 2006
    Columbus, Ohio
    1,107
    118
    Default SFM Formula
    I developed and used the simplified formula for teaching RPM for cutters since the earliest days of CNC, its
    SFM times 4, divided by the tool diameter.
    Its not quite accurate, the 4 should be 3.82, but it gets you so close, and it is easy to do in your head.
    A .5" drill in Mild Steel, using 100 SFM= 100 times 4, divided by .5= 800 RPM.
    In those days I worked for Swedish Machine Tool and we manufactured a 50 HP CNC lathe with a 10 step gearbox, it had no G96, so we had to figure the closest RPM for each cut.
    My job was to install the machine and teach the customer to make their first part or two.
    I learned in a hurry that I better develop a lot of easy to remember shortcuts and this was one of them.
    So is the info on my "Simplified Math for CNC" DVD, nobody in any of the shops I trained, had any idea how to figure angles, radius-angle tangent points, etc.
    "Keep it as simple as possible" and good luck: Heinz.
    www.doccnc.com
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    3.82 x CS ft/min
    -------------------- = RPM
    D in
    UNITS of measure ...
    you have to convert inches of tool dia to inches traveled in one revolution
    pi times the tool dia in inches gives you the total inches traveled in one rev
    but your still using inches....so....
    then to change the tools diameter to feet ....divide it by 12...
    Now remember how to divide fractions?... invert and multiply? right???
    So you left with 12 divided by pi... how much is that ??... 3.82 and change
    But as Heinz and others have pointed out... 4 is close enough
    Feb 2010
    Buffalo'ish
    9
    thnx for all your help guys, i realized i made a few mistakes like the rpm thing and it was 3.82 not 2.82 . thnx again for the info.
    JTS
  11. #11
    Nov 2008
    Chicago, IL
    1,550
    74
    140
    Actually, this made me look up something I've been wondering for a long while... what about Metric formulas?
    318.3 * CS / Diameter = RPM
    That is, where Cutting Speed is expressed in surface meters per minute and the Diameter is expressed in millimeters. Surprisingly, though, my Machinery's Handbook v28 has only surface feet per minute charts for materials. I realize I could convert them, but...
    Is there a Metric edition of Machinery's Handbook??
  12. #12
    Feb 2006
    South Carolina
    345
    39
    SFM = ( RPM x DIA ) / 3.82
    RPM = ( SFM x 3.82 ) / DIA
  13. #13
    Nov 2008
    mn,usa
    158
    6
    Now how about feed rate of end mills and drills? sorry for hijacking the tread but this seems like the logical next step in the post.
  14. #14
    Apr 2008
    Helmer, Indiana, USA
    1,167
    242
    455
    Quote Originally Posted by zach123 View Post
    Go until your snap it off and then back off just a touch.
  15. #15
    Feb 2010
    Buffalo'ish
    9
    Quote Originally Posted by Kyle Smith View Post
    thats great!
  16. #16
    Aug 2008
    SouthEastern Pennsylvania
    1,027
    12
    40
    I went to trade school in the 80s
    We were taught 4*cs/dia=RPM
    wher cs = cutting speed in SFM and
    dia = tool (or part in a lathe) diameter in inches.
    I get 5% more productivity using 4 vs 3.82
    Joe
  17. #17
    Feb 2008
    154
    Depends on the size of the cutters. Larger cutters can feed faster.
    Endmills
    Solid carbide endmills for steel, +/- 30%:
    1/4": 0.001 IPT (inches per tooth)
    3/8": 0.0015 IPT
    1/2": 0.002 IPT
    Solid carbide endmills for aluminum:
    1/4": 0.003 IPT
    3/8": 0.005 IPT
    1/2": 0.006 IPT
    Converting IPT into IPM (inches per minute):
    IPM = RPM * IPT * Z (number of flutes)
    Drills
    HSS: ~100SFM for steel, 200-300SFM for aluminum
    Cobalt: +25% over HSS
    Feed:
    1/8": 0.003 IPR (inches per revolution)
    1/4": 0.007 IPR
    3/8": 0.010 IPR
    1/2": 0.013 IPR
    5/8": 0.016 IPR
    3/4": 0.019 IPR
    IPM = RPM * IPR
    Since the vast majority of drills are 2 flute, we use IPR instead of IPT.
    These are general guidelines, YMMV.
    -Sol
    Glacern Machine Tools
  18. #18
    Mar 2004
    Waukesha, WI
    7,499
    701
    1817
    I use the 3.82 formula, and when I double check it against a lathe job that's running in SFM, it comes out perfectly at all diameters.
    But I can't figure out why the 3.82 is correct, when it seems to me it should be PI.
  19. #19
    Jun 2006
    Thunder Bay Canada
    1,731
    478
    265
    Quote Originally Posted by Dave K View Post
    3.82 = 12/pi
  20. #20
    Mar 2004
    Waukesha, WI
    7,499
    701
    1817
    Quote Originally Posted by 706jim View Post
    3.82 = 12/pi
    Ok, I see mathematically this is correct, but I still don't understand why this wouldn't be correct?
    SFM X Pi/ diam. = RPM.
