DMF_TomB
- Dec 13, 2008
- Rochester, NY, USA
got new facemill for finish cast iron. it uses modified triangle inserts not trigon
programmer says salesman says run 920 sfpm not sure where they got that, does anybody actually read catalogs anymore? . old cutter ran 550 sfpm (throws some sparks at 590 sfpm) so i figure try new one at 800 sfpm based on experience.
well new facemill finishes at 800 sfpm but throwing sparks actually a fair amount of sparks. maybe inserts dull at 75 minutes
of course manufacturers catalog say 330 to 820 sfpm so maybe 700 or even 600 sfpm better which is closer to what old cutter used. finish not bad actually shiny maybe inserts have better wipers at corners. i will indicate monday and see if flat within .0003" spec.
so do others run their finishing facemills throwing sparks finishing cast iron?? or do you slow till it stops throwing sparks ?? these are just carbide inserts
