One thing I havnt figured out is why when I create a turning program and simulate it to see what it looks like, my tool change position is way out in space.
I use machine postion numbers and just move my cutter to a safe area and hit "teach in" if I remember correctly. I hit simulate and single block to check for any collisions and my tool change position is somewhere out in space?
My tool is qualified correctly. I have the option to use "work" tool change postition but I dont understand what coordinates it uses.
Anyone have any input?
I never really pay attention to where the tools are going when they change in simulation. As long as they don't crash on the retract, I'm happy.
As far as the "work" tool change position, that just adjusts the tool change relative to your active work offset. It's way easier (for me) to just determine how much clearance you need from the face of the part, and put that value in. For instance, if I need 10 inches of clearance in z for the tool changer, I touch off on the face of the part, call that Z=0, then for a tool change position select "work" and change the "ZT" value to
Yes it should be that simple. I feel like my work offset isnt right or something.
When I fire the machine up I pick my tool and face the part or touch off and make that Z-0 in the "measure part" softkey. I do the same for X just to make sure my offset is accurate.
Then I write my program in shopturn and in the program header in the tool change position I can pick "machine" or "work". I thought "work" would be the location of my tool tip relative to my work that I just measured but that is not the case. So I pic "machine" and push the softkey "teach tc postion" with my tool in a safe postition and it uses that position for my tool change.
Do I need to set my work offset seperately from my tool offset? I feel like they should be the same.
is there a G53 or D0 on the safety move? If so it may be jumping to the turrets reference position.
Notice
