SIEMENS clock and counter, how do you do it?
Results 1 to 9 of 9
    Aug 2012
    Portugal
    121
    64
    Default SIEMENS clock and counter, how do you do it?
    Hi people!
    I am continuing to learn siemens control and now I have new doubts:
    1) How to see part time running? Is there any siemens command to do this?
    At the photos you can see the green message from MSG command,and the next comand is something i was just experimenting. Can i do it from one similar command?siemens.jpgsiemens_1.jpg
    2) Can someone post a macro for siemens part counter, please? I tried to do it but the R values do not work well ... I do not know how to do it.
    Thank you!
    Best regards!
    Aug 2002
    West Unity, Ohio
    23,102
    3402
    6392
    I haven't used the ISO side of the control enough to know what it takes to reach mine from that side.
    Doo you have SHOPMILL?
    Mine is available on the Shopmill side, but under a button that is likely built by the MTB as it lists the machine model in the button name (VMCII Data). It is a soft key along the bottom, but it is quite likely paid options. As you seem to have a very basic control, you may not have these options either.
    And for the record, I'd rather have a Fanuc counter! The Siemens counter opperates like "Take it or leave it". You can't just input any value in either register that you want.
    Think Snow Eh!
    Ox
    Mar 2008
    vacaville ca
    301
    21
    66
    Parts counter is pretty simple
    Create a sub l700 (what mine is)
    ;part count sub
    ;r90 for parts desired and set r91 to 0
    R91=r91+1
    If r90 == r91 gotof jobcomplete
    Gotof endcount
    Jobcomplete:
    Msg(“required parts reached”)
    M0
    Endcount:
    M17
    Then add l700 at the end of the program
    Aug 2002
    West Unity, Ohio
    23,102
    3402
    6392
    Think Snow Eh!
    Ox
    On mine- it is the bottom soft key - 2nd from the right. And it can be found on the tool offset page - which I am guessing is that same page in either format? Not sure.
    The name on the key is MTB designated, so I wouldn't know what to tell you to look for.
    Think Snow Eh!
    Ox
    Oct 2007
    UK
    1,742
    326
    420
    On 810 Shopturn running in Shopturn "mode"
    To see the general time, put this line in the control
    N145 MSG("TIME= "<<$A_HOUR<<":"<<$A_MINUTE)
    Last line of the prog was this, which called the "stats" sub prog
    N230 CALL "/_N_WKS_DIR/_N_TEMPLATES_WPD/_N_STATS_MPF";#SM;*RO*
    F_END(0,1,5);*RO*
    The "stats" sub prog was this
    PROC STATS DISPLOF
    N35 R5=$AC_CYCLE_TIME/60 ;MINUTES
    N40 R1=TRUNC(R5) ;MINUTES
    N45 R2=R5 MOD 1
    N50 R2=TRUNC(R2*60) ;SECONDS
    N55 R0=R0+1 ;PART COUNT
    N20 MSG("PART COUNT= "<<R0<<" : CYCLE TIME= "<<R1<<" MINS "<<R2<<" SECS : TIME= "<<$A_HOUR<<":"<<$A_MINUTE)
    M17
    This worked on using the R Variables
    R0 = Part Count
    R1 = Cycle time in minutes
    R2 = Cycle time in seconds
    R5 = reference used for calculating the above
    Aug 2012
    Portugal
    121
    64
    Quote Originally Posted by pcasanova View Post
    ;part count sub
    R91=r91+1
    Gotof endcount
    Jobcomplete:
    M0
    Endcount:
    M17
    Thank you!
    Aug 2012
    Portugal
    121
    64
    Think Snow Eh!
    Ox
    Thanks! I finnaly have found it lol
    Aug 2012
    Portugal
    121
    64
    Quote Originally Posted by barbter View Post
    F_END(0,1,5);*RO*
    PROC STATS DISPLOF
    N45 R2=R5 MOD 1
    M17
    R0 = Part Count
    Awesome! Thank you!
    Aug 2002
    West Unity, Ohio
    23,102
    3402
    6392
    So - did you find it, or you are able to roll your own with the macro help from these guys?
    Think Snow Eh!
    Ox
