AlfaGTA
- Dec 13, 2002
- Benicia California USA
I have a machine that uses older perm. magnet DC servos.
The one on the machine 's "Z" axis is giving me issues.
Servo is a Siemens HU 3078 0AC01
The problem is one of noise and seeming vibration that i can feel in the machine when the axis is moved.
Makes a rumbling sound , bets louder with speed.
Makes the noise although somewhat different in tone going up or down.
Have a similar machine with similar servo that i have swapped and the noise clears up with the exchanged servo...so i am focused on the motor....
I have had the servo apart and inspected the stator and commutator...all looks fine, no burned spots of discoloration to my eye.
I have replaced all the bearings in the servo, both on the stator and on the final drive support.
I am at a loss at what to do from here.....
Servo has a 24v brake and a DC tachometer as part of the package...as well as a right angle drive that is used for the hand wheel....
On re-assembly with the new bearings i was able to freely rotate the servo by hand by energizing the brake...no unusual noises
I really don't have a way to run the servo out of the machine (183 VDC)
Looking for any wisdom here as this is making me nuts......
Cheers Ross
Cheers Ross
