I bought an old kitagawa 6" chuck and when I went to mount it I found it had 7/16-14 bolts instead of the M10 the current b206 uses. The chucks holes are slightly over 12mm. to make matters worse it isn't mounted to a taper just a 5mm plain sholder.
Am i asking for trouble using 10mm bolts with it?
