WayneC369
Hot Rolled
- Jan 4, 2014
- ATL, GA, USA
I've got a customer who orders some knurled rollers from me for use in the mfg of tires. (I have a NDA in place, therefore, NO pics or drawings can be shared with you - Sorry.) The knurl is a 16 TPI Diamond, sharp, done on a manual lathe with a two roll knurl holder. Just to keep things interesting these rollers are tapered, or conical. As you all know this is supposed to be impossible to do. Well, I do it and as you might imagine the results aren't exactly stellar. While the customer accepts this finish, I want to provide something better in order to further differentiate my shop from the other local shops. Not to mention get this knurling job OFF that manual lathe as I don't like the pressures involved. I think it's ruining the cross feed screw.
I have sitting here an Okuma & Howa ACT-20 lathe with a Fanuc 18T control. I also have limited experience with this machine, however, I have about eight years programming/operating experience on CNC mills. FWIW I have manuals on this lathe which aren't the greatest. The MTB manual points to the Fanuc control manual while the Fanuc control manual points to the MTB manual on so many things such as capabilities. This is where I'm hoping you all can help.
Okay - I heard you say, "just get on with it already!" So, my question is: Can this knurl pattern be cut with a single point tool onto the tapered surface of this roller? There is an encoder on the spindle. Does this mean the machine is capable of multi-start threads, or rigid tapping even? If so, what's the limit on the number of starts? It seems to me a single point tool similar to a threading tool, held normal to the tapered surface of the part (with custom holder, of course) could be used to cut the pattern. But, I have ran into a few things already with this lathe that seem simple, but require hidden parameter changes, etc.
