Hi,
I have a Tormach 1100 and just got the 1/2" saw arbor for slotting saws. I am using a 2" diameter, 1/16 thick blade. I am brand new to these types of cutters so hopefully someone can help me.
The following is for 6061 Aluminum.
I spoke with Tormach and they provided a RPM of 2400 and feedrate of 2 IPM with a DOC of .050. This results in a very slow cut.
With that, I have to run 3 slots on a 4 1/2" cylinder (6061) with a final depth of 0.22855" and height of 0.125". This results in ~10 passes for one slot (5x at 1/16 height and 5x at final 1/8 height).
Can I run this thing any faster? I saw some calculations which resulted in a very low RPM and a higher feed rate (180-200RPM and 5.6IPM) but this sounds like it could get immediately caught up and break in the aluminum.
Any advice is greatly appreciated!
