EvolveES
- Dec 17, 2014
- Longmont, CO
Hi Everyone,
We have created a small program that we use for generating the G-code for tapping holes. We have had some jobs come through that require a lot of tapping and our Mastercam Machine file does not support rigid tapping. So we generated a small program to generate the G-code and used a tension/compression tapping head to do the tapped holes.
Currently the program outputs the correct code for our machine (a Tormach PCNC1100) using a G84 Canned cycle. Because of the delay at the bottom of the hole when the spindle reverses direction the T/C head gets stretched a little, but we have had no issues so far. The next version of the program will generate the code to manually plunge, stop, reverse, wait, and then retract, and this should eliminate the stretch on the T/C head. We also want to add drilling to the program so you can do all of the pre-drilling and then tapping without ever opening any CAD or CAM software. Below is a brief description of the program and a few screen shots.
The program is hosted on our website for download FOR FREE, just download the zip file and then run the .exe, there is a defaults .txt file that can be configured to load default settings but we will go over that later if there is interest. We just want to see if this is helpful to anyone else and get some feedback. If it is helpful we can do a instruction video, and a written manual on how to use it. If you have any features you think would be good to add or if you have any questions just contact us and let us know.
You can download the program from our webpage here: Portfolio :: Programming :: Desktop Applications
Soon to come: Drilling code generation & T/C Tapping without using G84 code
