Hi.
I have always been under the impression that when doing 5 axis simultaneous machining, you had to program the part with the work offset coordinate positioned in the center of the rotational axes, and that you had to regenerate and repost your program for every setup if you were unable to clamp the fixture at the exact same position every time.
I talked to some guys running DMG machines with Siemens controllers yesterday, and they said the Siemens controllers had a "Traori" function that could keep track of the work coordinate when the 4th and 5th axis rotated, so you could program 5 axis parts with the work offset placed somewhere on your part and it would stay at the same position on your part even if you rotated the tables and the tool axis changed.
I have worked only with Fanuc controllers and have not seen any mention of such a function.
Does anyone know if the Fanuc controllers can do this?
