I have a slight problem.
Machine is a 2014 Vf1 8k spindle. Now the spindle was replaced due to slight error of z setting on a tool. With that being said within 9 months certain harmonic sound was noticed at certain ranges of rpm. Such as 4.5k and higher. A professional did look at this machine. The one that replaced the spindle. To his advise or statement, spindle or motor is bad. The spindle is running ok 4.5 and lower.
No noticeable chatter, deflections, or tooling problems. Main material used is 6061 alum with very little tool pressure. With machine on high rpm I did hit the power off and I am not sure what else to investigate myself due to the cost of service. Seems they charge a bit more then I do.
I supposed there is a way to test if it is the motor or spindle by taking the belts off and testing the motor alone. The cog wheel was cleaned I had heard that might cause a harmonic sound. There is no bearing sound.
Tools I can still use are 60 deg engravers without tip breakage, so I do not think it is mandatory to repair. However, and ideal are to look into to save up for a repair bill would be great.
