Sparky961
Cast Iron
- Jul 10, 2008
- Vancouver Island, BC, Canada
What are the differences between a machine with the C axis option and one that just has spindle orientation? What does it take to convert the latter to the former? How do I know whether this machine has everything (mechanical and electronic) for the C axis? Are there some half-solutions that will give useful arbitrary spindle positioning?
More detail:
Control is Fanuc 0i-TC, and there are the buttons on the front panel for the C-axis and such. Nothing related to the C axis works though, so I'm trying to figure out what's missing, wrongly configured, or what I can cobble together.
In executing the spindle orientation (M19) command, I originally thought this might just be a lock or an index sensor but the way the chuck holds is certainly using PID to hold the position of the spindle (described elsewhere as "spongy"). So, this tells me there's a pretty decent encoder and control system there but so far I've been unable to make the spindle do anything but hold this single (repeatable) position.
There's a similar thread that gave a tip regarding the use of an "S" or "B" parameter following the M19 to specify an angle. I'll be trying this after the weekend but I'm skeptical because going through the parameters related to spindle orientation and positioning (in the machine) I found that only M18 (release) and M19 (orient) were specified - not the others that specify speed, angle increments, etc.
I can provide lots more information regarding the machine config if there's someone willing to work with me back and forth to try things.
More detail:
