I have taper problem that is really got me all stressed out! I am machining small diameter samples that require a tolerance of +-.001 on the OD. The diameter is .250" and I am using a 35 deg neutral handed insert and holder because of clearance issues. I am consistently seeing a .003 taper, small on the tail stock side. I am using a .016 nose radius and taking .010 for a finish pass on mild steel. I have been able to program a taper to counter the unwanted taper but it's not pretty. It's all over the tolerance in both directions. I'm assuming that I am dealing with tool deflection and maybe I need to find a better insert geometry?
I should have stated that the machine is level and not twisted.
