MuleResonators
- Jun 2, 2015
Good morning all!
My name is Matt and I own Mule resonator guitars. My hundredth guitar is coming up and I wanted to do something different. Dan Auerbach of The Black Keys had sent me his 1935 Dobro to check out after I sent him a Mule. It had some really cool metalwork. I'm looking to have a die made to stamp a wedge in brass for underneath the fingerboard.
I'm just winging it. I've been winging it since I started. It's proven difficult to get past the front desk of places with this idea.
I've attached pictures of what I'm trying to do. The material will be .025 half hard brass. Very low volume. This will be done for guitar #100, and I imagine I would maybe do 50 of these my whole life. Because of this, I was told about a company that 3D prints dies for stamping metal that can do it cheaper that machining.
I have a DXF, SLT, and DWG of the wedge itself drawn by a CNC guy in solidworks
I have zero experience with any of this stuff. I'm just a guitar maker. Something I had read that airplane guys do is rubber pad pressing. Just the male side of the die on guide posts pressed onto the brass into the pad. Think that's something we could do here? I have the rubber pad that was recommended for such a thing. I would make the press to use, perhaps a 50 ton car jack in a frame.
I also had the idea that this wedge would be machined on a 1/2" plate. The plate woul dhave four 1" holes in the corners for alignment. The female side of this die (if necesary) would have the same holes in the corners, and the wedge would need to be .025 (the thickness of the brass) larger than the male edge
I know this may be a bit different than what you are used to doing, I appreciate your patience. If there is something I can do to make it easier, let me know.
Also, if you do this kind of thing and would take on doing this project, send me an email or private message.
Matt
Matt
