plutoniumsalmon
Hot Rolled
- May 27, 2014
- Los Angeles
Hello.
Recently I had a job where I was using the master tool to provide a stop and zero for the face of the part. After cutting a test part I noticed that the zero its showing is not actually the zero on the part because it fails to show that the master tool has a negative z value. Without moving the tool to that z value where can I see it it in the control. Calibrating an Okuma 2-Axis Lathe with OSP-2 L CNC Control - YouTube. This is the procedure I use for setting the master tool and you can see that when he presses the cal key it sets a value on the z. Would the z value for the master not be zero? I failed to notice this before because I always faced off the parts before. Haas has a tool zero window does the okuma?
Thank you.
Thank you.
