Houndogforever
Hot Rolled
- Oct 20, 2015
- Boring
I have a 1.940" thick, cast aluminum sub plate that I am trying to mount on my Speedio.
In order to mount the 4th axis and give room for the clamps, I would have to extend the 4th completely off the table. The sub plate would hang about 6.5" off the table itself.
This would give me the option of leaving the 4th axis on the machine all the time so I don't need to re-mount it when running it. That would tend to give me incentive to run more 4th axis jobs as compared to just doing it the way I always did it and use vises and multiple setups so I could avoid the re-mounting and dialing in of the rotary face since that is a pain in the butt to get perfectly square.
Do you think this is going to be too weak or flexible? I have laid this out 9 ways to sunday but in order to get the face of the rotary even with the X- travel, it just has to fly out there. My only option would be to bump the rotary over 2-3 inches so about half of it is above the table, and just deal with losing 3 inches of table travel if I choose not to pull the rotary. If I HAD to have those inches, I could pull the table and do the parts, then remount the table.
I really only want to do this once. What do you think?
