Excuse me if you're already aware of this, but 304 work hardens, so you want a respectable feed rate. Kissing the work gently is a bad idea with 304. When you are cutting, cut. The feed rates suggested in the Carbide Depot link should keep you out of trouble.
I need to drill .500 dia. thru hole in 304 stainless,
Material is 1" thick,
Any: tool, feed and speed recommendation,
Thank you,
Material: 304 Stainless Cold Rolled 225-275 HB
Tool: 0.500in 2FL HSCobalt TiN Jobber twist Drill
Speed: 30.0 SFM/ 229.3RPM
Feed: 0.0039 in/tooth 0.0078 in/rev 1.78 in/min
Tool: 0.500in 2FL Carbide TiAlN Jobber twist Drill
Speed: 136.0 SFM/ 1039.5RPM
Feed: 0.0042 in/tooth 0.0085 in/rev 8.81 in/min
Speed: 204.0 SFM/ 1559.2RPM
Feed: 0.0042 in/tooth 0.0085 in/rev 13.22 in/min
304 SS varies considerably from cold rolled work harden to annealed condition
approximately the tensile strength is 2x higher and 2x harder to machine cold rolled or cold finished 304SS
so feeds and speeds got a spread in numbers. there is no exact answer best for all 304 SS
* So I will respond like this: "speeds and feeds too broad to recommend anything useful... But I have to write sumethin'"
8)
big difference in a guy with a low hp drill press and only hss jobber twist drills and another with a 20 hp cnc and carbide drills, a rigid part, good vise and through spindle coolant
not for nothing but i have bosses that fire a person if part scrapped and be pissed if you broke a $5 drill bit. makes a difference in how things are done
MAN!
You are super negative!
And/Or you are super unlucky(to put it mildly) to work with people like that.
I live in a perfect world compared to what you are talking about.
Luckily it does not seem like many people live in your kind of world.
Cheers!
Thank you,
Depending on part tolerance any one of these this should do it fairly quickly:
5 BMG Rifles
Notice
