Swagelok or Equal Drawings or Dimensions
Results 1 to 6 of 6
    Aug 2007
    Snowy Arizona
    1,236
    12
    170
    Default Swagelok or Equal Drawings or Dimensions
    I have a project that is of course HOT HOT HOT that requires a special tube arrangement. The Swagelok tube compression fittings are very reliable system and I was looking to use their ferrules and nuts, but I know they do not make the other end to fit the process equipment. Just so you know, I would love to be able to buy the off-the-shelf O-ring or NPT x compression fittings to make this work since they want them next week!!! The special end is pretty straight forward, just not a normal fitting, and I'm sure they cannot turn these out in a few days.
    So does anyone have prints or dimensions of the tube compression fittings? The only thing I really need is the body side ID info and OD thread length for either 5/8" or 3/4" OD tube.
    Steve
    May 2005
    Ohio
    394
    18
    99
    What is the other end you're looking for...have a basic drawing?
    Aug 2008
    Greensboro, NC
    27
    You can get Swagelok CAD templates here:
    CAD Templates for Tube Fittings, Instrumentation Valves, Ball Valves from Swagelok
    Just a FYI -
    Years ago we found that the Hoke Gyrolok was much less likely to fail when subjected to vibration.
    Instrument Valves, Actuators, Tube Fittings, Instrument Manifolds, Sample Cylinders: HOKE: Spartanburg, SC
    Aug 2007
    Snowy Arizona
    1,236
    12
    170
    Thanks for the help...but I have looked at all of the compatible fittings I could find for dimensions. The only real difficulty is the angle of the taper on the ID of the compression fitting where the tube slides into. The Swagelok drawings indicate the angle on the fitting does not match the ferrule, it is a steeper angle, which would make sense as the ferrule needs to have the front edge bite into the tube for grip and sealing - if the angles were the same, the whole ferrule would have to collapse around the tube.
    So, what I am really after is the taper angle and the major OD where the taper meets the end of the fitting.
    Steve
    Aug 2005
    CT
    7,532
    248
    1539
    Steve
    Try to look up spec AS33514 ( or consequently the older version MS33514)
    This is an aircraft specification for flare-less tube connections.
    Should be available on line.
    Jan 2008
    Canada
    344
    10
    31
    look at parker too
