PriddyShiddy
Cast Iron
- Mar 1, 2011
- anaheim, ca
I have a production part I need to increase sizes and speed on. The parts are roughed on a 4 axis lathe with live tool currently. Part is 5/16 diameter O1 bar stock, milled to a 1/4 x 1/4 square shank 2.55" long and parted. That leaves original 5/16 diameter corners for smooth edges. I need to make 5/16, 3/18 and 1/2 soon and need to get the daily run time down from it's current 18 hours to make 400 parts.
"But why don't you..."
Do them on the mill: Labor cost is enormous to have someone standing and loading them 1/3 of each day
Buy square stock: because no one makes it. Only precision flat ground and it costs 5x more
Can a Swiss Type lathe such as a Cubic SD16 or Hardinge ST-220 make these? It would need to feed while side milling 4 sides and retract after three of them.
Would the bushing hang up on the bur from the first, second and third size making it a non-starter?
Do the milling spindles on these things have the balls (bearings) to side mill .032" DOC all day long?
Are the tool position offsets fixed or can you use tool ## offcenter to side mill as it is fed or can you only feed dead nuts on the tool line using the tip of the EM rather than the side?
I run these on a axial live tool so the tips of the EMs constantly chip even with a live center supporting the end of the bar. The feed-n-cut style seems like it would save me the time to center drill, pull, move center etc. Bonus.... HUGE bonus would be the $4,000 worth of chipped tipped EMs I have would go from scrap to gold since I could use them on their sides.
