I have a problem at work and not sure what to do/how to fix. I have a 2-56 STI thread cutting tap (3B) that is cutting oversize. The NoGo gage is going in very easily, yes, it is also a 3B gage. Here is what I mean by "not knowing what to do or how to fix it" -
The drilled hole is to size, called out in a couple different charts as a 3/32". I checked the hole size, a .094 gage pin goes in, a .095 does not.
The Helicoil chart I have says the hole should check from .089-.096 after it is tapped. I check the hole at .094/.095 after it is tapped.
So all the data (although limited) says I should have a good thread, or at least everything up until the threading part is correct. What else can I do or check if my holes (before and after tapping) are within spec? To note, the thread gage (Balax brand) lists the GO as like .0963 and the NOGO as .0976 (or something close, I remember it is only .0013" difference between them). Here are the details I can think to list -
OSG brand tap, 2 flute, spiral point
Solid (not the spring loaded kind) quick change holder, runout TIR less than .002
840 rpm, 15ipm
Haas UMC-750 with rigid tapping, retract speed set to 2x
6061 aluminum plate material
Castrol Hysol MB50 (I think that is the brand, not at work now) at approx 10% mix
A few questions up front, could the gage be wrong by any chance? It is brand new with certs FYI, but mistakes happen... Could the tap be labeled wrong or be bad? Seems like .0013" total is awfully tight for a $20 tap, but I am not familiar with all the different classes of fit. If I drill the hole undersize (next drill would be .0895, I think) would it make a difference on the thread gage? Not really too familiar with thread gaging, most places I been it has always been just tap it and if the bolt threads in and gets tight its a "good" thread...
It's possible I don't have a 3B tap, not at work to double check this, but pretty sure I checked this to the print spec so I ordered the 3B gage, I assume (you know how that goes!) that I also ordered a 3B tap at the same time... To that point, anyone know the difference in spec between 2B and 3B? Is it enough that a 2B tap/thread is bad checked against a 3B gage?
840 rpm, 15ipm
